Yamaha oil control unit wiring
I have a 1985 115ETXH. I bought a replacement oil control unit and it was an updated version that substituted the original. From what I understood in the directions, I ran a lead wire over to the terminal for the #2 coil pulse line. I think this is in place of the old mercury switches. But, I'm having trouble. The orange oil light seldom goes off. I often see it slowly flashing like the pump is turning on and off repeadidly. It does pump oil up usually, every now and then it doesn't pump the oil up and the alarm sounds. I use the emergency switch to refill and then it's fine.
I'm guessing I wired it wrong, maybe it's not supposed to be hooked up to the pulsing power from the coil??
