  #1
Old August 8th, 2006, 11:17 AM
justinhip justinhip is offline
Default 1992 evinrude 250 V-8 cooling question
When I first ran the engine on the hose, the piss stream was a little weak. Figuring it'll get better once in the water, I tried it but not really any better. So I did the WP and tested it again. The stream is better but not great (at least as compared to my Yamaha). Its not overheating but it just seems odd. Also, if I shut the engine to drift fish, I notice at restart it takes a bit to get the piss stream going and I also hear a brief pressure relief at the port before it begins pissing, is this normal? I assume the engine has huge water jackets because after I disconnect it from the hose, it drains for quite a while thereafter. BTW, is there anything I should be looking for specifically.
Thanks
  #2
Old August 8th, 2006, 12:16 PM
AlanR AlanR is offline
Default Re: 1992 evinrude 250 V-8 cooling question
Change your water pump. Also the thermostat some times only lets it piss water if the water is a ceritan temp. my merc did that, but im not sure about 'Rude
  #3
Old August 8th, 2006, 12:55 PM
So you think it may be bypassing some of the water because it is not needing it all, hence weak stream? I did the pump, and noticed a slight difference but nothing groundbreaking
  #4
Old August 8th, 2006, 01:09 PM
No not quite.. Does it pee more water when ur driving it faster? because my Gt150 doesnt pump much water at an idle but when im driving like fast it pumps pretty good
Also if you can put ur boat on a trailer with Muffs on it and see if water pours out of the whole above the prop... Cause that little pee hole dosnt always mean its not pumping water. My 65 Johnson never pumps water our of the whole or it just dribbles but it comes out of the hole above the prop
  #5
Old August 8th, 2006, 03:17 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
What you're seeing is quite normal for a looper V8. What's the water pressure at idle and at WOT?
  #6
Old August 8th, 2006, 04:45 PM
Quote:
Thats what I still have to determine. I have gauges on their way. I have been just putzing around listening for the idiot alarm. I got an intermitent beeping on my first outing after running almost WOT for a minute or so. After, I did the WP and have not had it. I am anxious to get a WP gauge because that will tell me what going on. My guess is that shes pumping pretty good. There is a tee from the previous owners pressure guage already inside that is capped off. I was running her a bit harder and noticed water dripping from the cowling. I slowed to a stop and pulled the cover and water was gushing from the hose. So, I suspect its pumping quite well.
  #7
Old August 8th, 2006, 07:53 PM
Where is the T located?
  #8
Old August 9th, 2006, 08:43 AM
Its right in, guessing a 1/8" line thats running between the piss stream port and and lower portion of the block (I think). I am going from memory here.
  #9
Old August 9th, 2006, 11:55 AM
Water pressure on a looper is read at the adaptor plate. There are a couple of allen head screws in the adaptor plate on the starboard side. That's where you hook up the line to the gauge. If it's T'd into the overboard indicator line you'll get a very, very low reading. Probably 0 at idle and maybe 8-10 at wot.
  #10
Old August 9th, 2006, 03:02 PM
Ok, this may be dumb, but what is the adpater plate you are referring to? On the starboard, lower/rearmost portion of the motor just above the cowling, there is a plastic fitting screwed into there. Thats the line the WP gauge was teed into. The line will just go directly to the gauge without any sort of bypass? On my Yamaha it is like that but it picks up on the top of the head behind the thermo housing. What should I be seeing for idle and WOT in terms of water pressure?
Thanks
  #11
Old August 9th, 2006, 03:59 PM
The adaptor plate is what the powerhead sits on. sounds like you've got it located. Depending on what pump you have in the motor you should see about 4-5 at idle and over 20 at WOT.
  #12
Old August 9th, 2006, 04:22 PM
Ok, Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 15HP Evinrude Carb Question dnye1 Johnson & Evinrude Outboards 2 October 2nd, 2005 08:19 PM
Points question, but- 1992 40hp evinrude!!! SN75AKE Johnson & Evinrude Outboards 15 September 21st, 2005 10:51 AM
1994 225 evinrude cooling question wallco1 Johnson & Evinrude Outboards 5 April 8th, 2004 04:34 PM
1992 70 Evinrude cooling T fitting. Tristar Johnson & Evinrude Outboards 3 August 4th, 2003 03:28 PM
1992 Force 70 HP Cooling Question Howler Force & Chrysler Outboards 2 August 3rd, 2003 05:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
