control problem
imported_jeff h
77 evinrude 140changed, the empellerfollowed, the manualhad, it in reverse throughout the processafter, completion thought i'd check it out and it wouldnt' crankand, the control handle was not traveling back to the neutral switchtook.. the controls apartthe( motor shifts fine with the cables removedfinally) after about 5 trys igot it to work long enough to put muffs on and shift it fwd and rev a couple timethought. all was well pushed it back in shop tried it one last time and the control locks up just fwd of neutral right back where i startedi. did not adjust any cables during impeller rplacement. just curious why do you puy it in reverse during pump replacement?
tashasdaddy
Re: control problem
to make connecting the shift rod easier.
Walker
Re: control problem
That shift rod has a gooseneck bend at the top right??
You probably have the bend towards the rear. It must be forward or it binds up the shift linkage
imported_jeff h
Re: control problem
not sure whatyou mean by gooseneck the connector at the top of the shift rod is about 5/8 dia machined down to about a 1/4 flat on 1 side.that all moves freely with the cables unhooked but the control box is still locked up .is the a special way to orient the control box during assy.it sure seems stiff to shift theres some wear on the detent ball area.dont see anything broke or missing
Walker
Re: control problem
Okay, yours is an older style. I wasn't sure what year it changed.
In your control box the control lever moves a nylon gear with only 3 teeth. That gear must be syncronized with the cam that it meshes with. Once you open the control box you will see what I'm talking about. Yours is probably jumped one tooth and out of sync.
imported_jeff h
Re: control problem
[so how do i get it back in sync i.ve tried several times with no luck do you think its hanging on the detent ball .thanks for the response what if i take the ball and spring out
tashasdaddy
Re: control problem
the detent ball is part of the neutral saftey switch i believe.
KYHunter2
Re: control problem
Not the detent ball. I believe he's talking about the 3 tooth , kind of like a partial gear .
It has to be aligned correctly , where they mesh.
I doubt the detent ball ,even if frozen.
Would make it as hard to shift as you describe.
KYHunter
D
DJ
Guest
Re: control problem
Just did all of what you are talking about wth a '75' Johnson-50.
The control box is a nightmare, for the novice. But, when you settle down, and LOOK at it, it's really simple.
1. There is a nuetral safety switch, in the front-true.
2. The "three fingers" must be aligned with the three on the control bellcrank.
3. The easist way to get the nuetral "ball" into place is to remove the spring cover and then place the ball and spring. Then replace the cover and tighten.
The whole trick is to finish the inside stuff-FIRST and build-out..
By doing this you satisfy the nuetral safety switch and the are ready to "place" the nuetral ball/spring.
4. After that, just place the outside cover on, making sure the throttle cable stop is in the slot-in the control cover.
Ther is NO simple way to describe it. But, it is SIMPLE to anyone that will look at it for awhile..
KYHunter2
Re: control problem
djohns19,
You said it , sometimes there's no good way ,to explain in words, how to do something.
I remember , the first few times I fooled with one .
If you don't assemble ,exactly in the order you take apart.
You'll end up starting over. LOL
Really is simple, once you get into it.
KYHunter
jeffch
Re: control problem
ok so i need to build it in neutral?does the cable thats attached to the main housing need to be in a certain position?how do you think it got out of whack and locked up anyhow ?with the cables off if there a possibility it went over center or somrthing?thanks for the help i will attempt it again tonite,had thunderstorms yesterday
