Hi all... new to the group and new to the Suzuki outbout motors. :^
I bought an 85 model, DT40 a while back and have slowly been resurrecting it from 3 years of storage. It's on a 16ft runabout. Gone right though everything that needed, or might need doing, (impeller, carb recondition, gear oil, plugs, timing, etc,). I had it on the water for the first time today and it seamed to run ok (nothing spectacular) at low to medium speed, but when I run it full throttle the motor dies after about 2 minutes. It starts again after a fair bit of cranking but the same thing happens again each time I run it at close full throttle.
I suspect the fuel pump is not working at full capacity. The last time it stopped I saw that the bowl under the fuel filter was just half full. I disconnected the hose from the pump to the carb and cranked the engine over but no fuel came from the pump until I primed it by squeezing the hand pump on the fuel tank line.
I ulled the pump and stripped it down but cannot see any obvious problem with the diaphragm. I did notice that one of the metal flapper valves (on th eintake side I think)was not fully closed against the pump body. I'm not sure if this is relevant....
So... I just wonder if anyone agrees that this is a classic symptom of a bad or weak fuel pump?
Thanks! and greeting from the fjords of Norway!
Bill Carr
Bill Carr
