  #1
Old August 7th, 2006, 06:03 PM
Pete E Pete E is offline
Default 88 5hp Mariner compression check
Does anyone what it should be ? I've got the motor dialed in but it still seems sluggish. The plug is a light charcoal color. It almost sounds like it not getting enough air. I've cleaned the carb and check twice to see if some gunk has loosened up. I've turn air/fuel in and out alittle but no change. Any other idea's? I've got a 12 ft tin can with about 400 lbs in it with me and family plus other gear. I would think the motor is big enough but we just putt along. I swear I could paddle my yak faster.
  #2
Old August 7th, 2006, 07:25 PM
05GlastronSX 05GlastronSX is offline
Default Re: 88 5hp Mariner compression check
its not so much the number readings, all that matters is that the cylinders are within 10-15% of eachother. Id guess that yours is a singer cylinder though, so that may not apply to you. Anything over 70-80 would be considered acceptable IMO.
Also, i dont think 5 hp is enough for that boat when your hauling a few people and their gear. anythying less than 7.5 is inadequate. a 9.9 would be nice especially for the extra load and a 15 might be overkill and thats if the boat can even hold it.
__________________
2005 Glastron SX 170
2005 150 Mercury XR6
1999 fisher V-1667 utility
1992 Mercury 40 classic (4cyl)
  #3
Old August 8th, 2006, 04:13 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
I have a 5hp mariner (single Cylinder) it will only putt along, you can only get it on plain on a light boat with 1 person in, these are very strong motors made for trolling ..... air screw should be turned in to soft stop then out 2 and a half turns .... compression should be about 80 - 120 then ok ....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #4
Old August 8th, 2006, 11:01 PM
Darn, I was hopeing it was something mechanical. I had a hunch it might be to small for the boat. Well guess I'll search for a older 9.9 or 10 horse. That's the max for my boat. Thanks for the help
Pete
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Compression Check: bjperry Mercury & Mariner Outboards 7 March 15th, 2007 10:14 AM
compression check Thumpbass Johnson & Evinrude Outboards 10 September 23rd, 2006 11:14 PM
compression check dcar00 Force & Chrysler Outboards 1 July 8th, 2006 09:56 AM
compression check Irish Rob Force & Chrysler Outboards 3 June 29th, 2005 07:03 PM
OB compression check?? chrisross Johnson & Evinrude Outboards 1 October 26th, 2000 04:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
