  #1
Old August 7th, 2006, 05:08 PM
Bob Moss Bob Moss is offline
Default 1985 Mariner 150hp Running, but seems very tired
Hi, Thought I would run this topic by you guys to see if you can offer any advice. I have a 1985 Glastron 16' ski boat, with a 150 Mariner outboard. I have owned the duo since summer '87, and I have never had any issues with either. My brother (225 lbs) and I (190lbs) have slalom skied behind her hundreds of times. She used to pull us out of the water instantly. With the stainless propeller, she had so much bottom end torque that we nicknamed her the stump puller. Now, she is acting tired. With a light load she will still cruise all day at 45mph, but she doesn't "rabbit" up to speed anymore. Add a few hundred more pounds of passengers, and she is much slower still. She still gets up to top speed and sounds just fine, but she doesn't do it with zest. I have had my mechanic (a good general mechanic) check her and he says that all is fine. I know it isn't, but I can't really explain to him what she used to be like. How do I go about getting her back to her old self? Are these recognizable symptons of a common age related development. I love the boat and motor, and although I am no longer skiing very often, I would like to continue to do so in the future. For now, I have to let others pull me. Thanks a bunch!
  #2
Old August 7th, 2006, 05:46 PM
KCLOST KCLOST is offline
Default Re: 1985 Mariner 150hp Running, but seems very tired
Let's assume that the motor "is" ok like your mechanic says...
Is there any water in the hull, is the boat hull clean, any barnacles or stuff on it? And are you using the same prop that you always have?
  #3
Old August 8th, 2006, 07:48 AM
Kevin W Kevin W is offline
i have a few possibilities:
Check the compression.
it is most likely not as good as it was in the earlier days.
more compressoin= more torque = more stump pulling ability. I am sure its still useable but maybe not quite as good.
also the newer gas has ethanol alchohol in it.
10%ethanol gas does not have as much power producing ability as 100%gasoline.
It could be a combination of both things.
  #4
Old August 8th, 2006, 11:56 AM
There is no water in the hull that I know of. The gas tank is up there, and I have no means of access. However, the attititude of the boat sitting in the water makes me think its fine. The hull is clean. It has been sitting on very clean fresh water its whole life. As for the prop. Years ago I switched to a stainless with a pitch geared towards bottom end. The boat got much stronger when this change was made. Last year I tried the boat with a spec prop and the stainless. Same net result. Thanks.
  #5
Old August 8th, 2006, 12:00 PM
Not sure about the gas issue. I am looking to find a dedicated Mercury mechanic that will be hopefully knowledgable and honest. You are probably right about the compression, and that will be the first thing I will have him check. Short of a complete rebuild, any chance that it might be a simple fix to restore her zest? Thanks.
  #6
Old August 8th, 2006, 12:20 PM
05GlastronSX 05GlastronSX is offline
de-carbon might just do the trick. use some sea foam a.k.a deep creep. Its worth a shot. It can be a cheap, easy fix.
__________________
2005 Glastron SX 170
2005 150 Mercury XR6
1999 fisher V-1667 utility
1992 Mercury 40 classic (4cyl)
  #7
Old August 8th, 2006, 03:26 PM
Quote:
That's interesting. How do you apply it? Where do I find it? Thanks.
  #8
Old August 9th, 2006, 01:57 PM
Decarbing may be a very good solution:
http://forums.iboats.com/bbBoard.cgi...6;gtid=1035563
here is the proceedure listed under FAQ
  #9
Old August 14th, 2006, 12:46 PM
Thanks Kevin, getting set to try this out on the weekend!
  #10
Old August 14th, 2006, 05:44 PM
LubeDude's Avatar
LubeDude LubeDude is offline
I didn`t check this particular link out as to which one it is, but do the small tank decarb procedure, also spray some into the sparkplug holes too. I prefure to let things set overnight if I can. It will likely add new life to your engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 1985 50 hp running slow srussell28 Mercury & Mariner Outboards 4 June 1st, 2006 05:14 AM
1985 v6 evinrude 150hp doug7413 Johnson & Evinrude Outboards 2 July 26th, 2005 05:45 PM
Mariner 1985 200 hp running rough. Truant Mercury & Mariner Outboards 3 February 9th, 2004 07:17 AM
Mariner 1985 200 hp running rough. Truant Non-Repair Outboard Discussions 1 January 2nd, 2004 04:05 PM
1985 150hp running hot coolmavrick Mercury & Mariner Outboards 5 October 14th, 2003 10:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
