Recently smoked an impeller after running the engine dry (ear muffs had vibrated off the intake, didn't realize...etc). Installed the water pump kit and when re-installing the lower unit, did not guide the copper water tube into the water pump properly. Jammed the copper tube (so it kinda resembled a "z" in there instead of say a nice candy-cane shape up to the block) and pinched it, possibly in 2 places. Even though I was able to straighten it out some, pinch is still there and when installed, discharge only dribbles water.
How can I replace this tube? Is there any quick fix otherwise that anyone knows of? Other than emptying the gas can on the POS and throwing a match at it?
The model # is (Johnson) J40 ECRM, again, 1984.
Thanks a lot.
Greg
Thanks a lot.
Greg
