Trying to get this old motor to run, but no luck so far. I've got spark, but motor won't fire. Took carb apart and cleaned/soaked with cleaner. She's got about 80# compression on each cylinder.
How many turns should I back the slow speed rich/lean needle out of its fully seated position?
What plugs does it take, and what is the gap?
Is 80# compression enough to run?
Thanks
Thanks
