76 70 H.P. Evinrude
imported_Tyrone
I just bought this boat and don't have a lot of knowledge of boats so any advise would be appreciated. The upper and lower spark plugs has fuel and oil on them but the middle plug doesn't seem to be getting any. but all 3 plugs are firing, and all 3 carbs. are getting gas. Any methods of trouble shooting or fixes. thanks Ty
rickdb1boat
Re: 76 70 H.P. Evinrude
Hi Tyrone
If # 2 is not getting fuel, then you have a clogged up carb on that cylinder. Don't run the motor like that or you will fry the piston that's not getting fuel. Remove and clean the carbs and use a rebuild kit on each....A Manual will be your best friend for jobs like this....
