I believe I have a bad stator. My motor was running great untill last weekend. It normally revs up to about 5500rpm. It will only go to 3000-3500 now. It seems to run pretty well, but will not go past 3k. I've checked the fuel system & everything seems to be in order. At 1k rpm the high leads are about 140v each & low are 20. At 3000 rpm one high lead is over 200 & the other has dropped to 50. I'm pretty sure that is the problem, just looking for confirmation before ordering expensive parts.
Thanks
Thanks
