  #1
Old August 4th, 2006, 10:18 PM
cknadroj cknadroj is offline
Default Opinion on aluminum boat modification
I’d like to remove the circled part (x 4) so my new floor will fit better. Previous Captain cut these seat mounts down – not me. They were not covered - they are a bit dangerous actually.
Both are stress cracked on the starboard side so they provide no structural purpose on that side anymore.
Please let me know your thoughts/opinion.
  #2
Old August 5th, 2006, 12:23 AM
fishingdan fishingdan is offline
Default Re: Opinion on aluminum boat modification
Personally, I think that hull has been weakened significantly by the previous owner and if you remove the circled structure, it will be worse. Without proper support, the hull sides could simply collapse in.
Those benchs/thwarts are structural.
  #3
Old August 5th, 2006, 01:06 AM
"Those benchs/thwarts are structural.", he said.
He is correct, and it has been comprimised.
I'm gonna take 'em out.
  #4
Old August 5th, 2006, 08:56 AM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
What do you have designed or planned to replace the support with? You can have those cracks welded and install more aluminum and have that welded or rivited in. I would strongly advise you make a stucture that is supported or the sides will collapse in.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #5
Old August 5th, 2006, 12:11 PM
NBE NBE is offline
Yes, take them out.........all of them if you want. Who cares? It's your life! :devil:
  #6
Old August 5th, 2006, 12:55 PM
Mark42's Avatar
Mark42 Mark42 is offline
Yep removing the bench seat without adding back some alternate support was a big mistake.
If you want the open floor space to use as a fishing platform, you can keep the center section open, and add two Jump Seat style seats to the side that double as supports.
Cut plywood or aluminum triangle shapped braces, say about 20 inches tall, and 12" on the bottom. Make them conform to the hull sides and floor so they can be through bolted to the bottom rib and up along the gunnel. Put two on each side, then add a horizontal seat base to them. You should be able to sit with your back against the gunnel, and still have open floor for walking/standing in the center. This will add back enough support that the sides will not just collapse in when you get two big guys standing next to each other in the boat.
Kind of hard to tell the size from the photo, but my guess this is about a 12' boat, with 5 foot beam, right?
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #7
Old August 5th, 2006, 06:21 PM
OK, you fellers win. I'm going to put an "original" style seat structure back in.
I got it all ready today - cut off the bent part of the remaining structures so I have nice flat surfaces to rivet aluminum sheet to. Don't worry, the aluminum sheet will have aluminum angle riveted on at both the top (for the seat mounting surface to attach to) and at the bottom (for the floor to attach to) to make it nice and rigid.
The seat structure will be about 52" across by 15" wide and about 8" deep. I will either put in foam or use it for storage inside.
Now all I need is two pieces of sheet and the angle.
  #8
Old August 5th, 2006, 11:28 PM
Bob_VT's Avatar
Good choice.
__________________
  #9
Old August 6th, 2006, 01:18 AM
For what is worth, here is where I'm sort of headed +\- with this boat - '61 Malibu 14'- only a more spartan interior.
  #10
Old August 6th, 2006, 11:04 AM
Mark42's Avatar
Wow! That is a nice looking boat! Not too many classic closed bow runabouts in aluminum available. Love the 50's - 60's fins out back. That is rare on an aluminum boat. When you look at the boats with fins from that era, they are almost all fiberglass.
If the windshield is shot, a plastics fabricator can make a new one for you. They will need the old one. That would probably be your greatest single expense to restore it. Otherwise, upholstry, gauges, controls and paint won't run you more than $1000 - 1200 if you buy everything new. Plus the cost of fabricating the missing rear seats.
If you rent a sheet metal brake it would be cheap to fix yourself, plus you could build a custom splashwell for the rear or some storage compartments back there to hide portable or permenant gas tanks, battery, gear, etc.
Oh boy, oh boy, oh boy, I can hardly wait..... d d d
Are you going to bring it back to its original configuration?
I see the boat looks stripped, did you remove all the steering and controls or did you get it that way? Man, that should be a fairly easy restore. Please tell me you're not going to turn that into a platform fishing boat. Its just too nice a design to mangle.
Give us the link shareaproject for your boat. C'mon what are you waiting for?
__________________
  #11
Old August 6th, 2006, 01:20 PM
Here is the shareaproject link. Don’t worry, I’m not going to hack it up, even though we use it mainly for crappie fishing. As you can see in the pictures, the boat is complete including the original windshield. Look close at some of the ‘before’ pictures and you can see it already has a splashwell. The only thing I'm missing arethe Lone*Star emblems for the sides - hard to find.
I took it all apart this spring and media blasted every square in of it in preparation for new paint. The paint scheme in the picture is from 1958 – I like it better that the 1961 scheme mine had (at some point in the past).
IÂ’ve already made all new modular (removable) wiring harnesses for it. I will probably go with updated steering rather than putting the cable/pulley system back in. All I really need to do it get the seating and flooring worked out, get it painted, and then reassemble it and it will be ready to go back to the lake. I have the original 1961 40HP Johnson that came with it.
http://www.shareaproject.com/pages/p...,p,145,00.html
Here are some pictures of another Malibu that has been restored.
http://community.webshots.com/album/548979678oIsMFq
  #12
Old August 6th, 2006, 05:32 PM
Mark42's Avatar
__________________
  #13
Old August 6th, 2006, 05:36 PM
Mark42's Avatar
Wow! Nice work! I hadn't seen the project on Shareadprojet before. Must have missed it. You are really moving right along. And the idea of a modular wire harness sounds like a good design.
I think you will really like the feel of a new rotary or rack system compared to the wire/drum system. I see that the blue Malibu has a newer cable system and is using the right hardware to connect to the pre-steering tube motor. I guess the owner couldn't bend the cable tight enough to thread the cable through the original steering cable hole in the fin. I can tell you from experience with fitting the cable to my boat that the cable is stiff and does not like to bend in a very small radious.
Are the seat cushions/upholstry going to be removable?
You mentioned flooring. What did you have in mind?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
your opinion - PVs on your boat PV boat Non-Repair Outboard Discussions 6 October 28th, 2006 02:57 PM
aluminum boat... aluminum stringers? diaboy5681 Boat Restoration and Building 6 October 17th, 2006 09:17 AM
Aluminum Boat Transom Modification. pnut Boat Restoration and Building 4 July 9th, 2006 11:58 AM
Need Opinion on Fastening Transom on Aluminum Boat cclaeys Boat Restoration and Building 6 August 26th, 2004 09:09 PM
Aluminum mod. v boats,opinion help Barlow Boat Topics and Questions (not engine topics) 11 April 14th, 2003 10:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
