Re: yamaha 115hp V4 dead spot
PJ.
I had the same problem not too long ago. It turned out to be a bad fuel pump, the diapham of the pump had a tiny hole in it. At low speed, it flooded the spart plugs causing the motor stalled when taking off. At higher speed it ran fine. I changed a new the fuel pump that solved the proplem. Wish you luck.
