Mercury Alpha outdrive
Mark Burzik
I seem to be adding oil to the lower unit but, with the boat parked on the trailer in the driveway I do not see any leakage. Any ideas?
Bt Doctur
Re: Mercury Alpha outdrive
Find the leak before it takes out the drive.There is no loss of oil unless there`s a leak. fishing line behind the prop for a "rotating leak"?Any gear oil in the bilge? carrier seal or yoke leaking.
tystick
check your bilge - it could be the yoke seal
Haut Medoc
Drain your drive & see what the gear lube looks like....
Then pull the drive & look in the bellows for gear lube....
Next, pressure test the drive.......
At least that is what I would do;).....JK
