  #1
Old August 1st, 2006, 02:05 PM
robert.massengale robert.massengale is offline
Default 1986 75hp Mariner 4 cylinder
I would like to establish a discussion group about the 75 hp mariner 4 cylinder. If anyone has this same motor and would like to get into a discussion on an ongoing basis please let me know your email. robert.massengale@gmail.com
Thanksd
  #2
Old August 11th, 2006, 08:31 AM
mikael.block mikael.block is offline
Default Re: 1986 75hp Mariner 4 cylinder
hi robert
I have a marina 1984 75hp..
I think it is great to help and share knowlegde...
I'm in.
Mikael
  #3
Old August 5th, 2007, 02:05 AM
dinikin dinikin is offline
What's the diffirence with Merc.
__________________
1986 75HP 4 Cyl. Merc.
  #4
Old May 30th, 2008, 03:58 PM
great_lakes_dan great_lakes_dan is offline
Quote:
Thanksd
HI
I have a 75 Hp Mariner. 4 cylinder 2 stroker. 86ish. I just put out a Thread on it. with Spark but not firing on Cylinder 2.
my Email address is
dsolovy@comcast.net
Thanks
Dan~ MIchigan
  #5
Old May 30th, 2008, 08:30 PM
coyedsel coyedsel is offline
86, 75HP Mariner. No spark to 1&2 cyl. Have not determined cause. Just started working on problem
  #6
Old June 30th, 2009, 11:38 PM
melhxi melhxi is offline
I just purchased a used boat with a 1986 Mariner 4cyl 2stroke. I changed the impeller and all went well until I tried to get the lower unit back in. It stops solid with about a 1" gap between the machined surfaces of the upper and lower units. I've tried every trick to ensure things are aligned but I can't budge the LU closer than the 1" gap. Any one solve a similar problem?
  #7
Old July 6th, 2009, 05:29 PM
al9981 al9981 is offline
I have a 86ish 75hp Mariner 4 cy as well. It had been seatting for 7 years and it fired right up. I had to change the impeller on it and that s it.
melhxi:You may have to wiggle the prop to get the spline on the drive shaft to engage.good luck
  #8
Old July 9th, 2009, 05:48 PM
rcmickey's Avatar
rcmickey rcmickey is offline
Yo! I have a 91 Mariner 100HP. I understand they are pretty closely related. I'm in the process of installing a new impeller and kit. I just got it with a PrinceCraft I bought.
__________________
Just when you think you know all the answers to all the questions........they change the questions!!!
  #9
Old August 18th, 2009, 05:49 PM
Jim Lockwood Jim Lockwood is offline
Hello All,
I have a 1986 Mariner 75Hp and have just encountered a problem recently; the mortor has always ran great and then one day I went to start it and it took the choke to get it started (after it was warm already) and high throttle to keep it running. It will not idle and when I go to put it into gear real fast it dies. Any thoughts? It does not smoke but very little which is not the norm. It has a oil injection poly bottle in the battery compartment but I think it's mixing ok. I was told to cut that thing loose and mix directly into the fuel tank. can you confirm this?
Thanks,
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Headless ?1986 20 HP Mariner 0A73006 Water in cylinder w2much Mercury & Mariner Outboards 1 July 11th, 2006 12:22 AM
75hp Chrysler No spark in one of three cylinder northworm23 Force & Chrysler Outboards 1 May 30th, 2006 04:38 PM
1986 75HP Stalling when put in gear hkellar Mercury & Mariner Outboards 4 May 30th, 2006 06:31 AM
Looking 75hp Mariner 4 Cylinder block Goldy0098 Mercury & Mariner Outboards 1 May 5th, 2006 06:25 PM
No spark #1 Cylinder 1983 75HP Evinrude 71whaler Johnson & Evinrude Outboards 11 August 9th, 2005 01:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
