Re: (Compression) 85 hp evinrude
In my opinion, at sea level, 650 cca fully charged battery, throttles in full warm-up position, motor at operating temperature, all plugs removed, using screw in tester, 110 to 135 psi.
Variation not to exceed 10%.
Indications: if lower or if variation exceeds 10%, decarb and retest; If decarb fails to improve, buy the cylinder head gaskets and visually examine the cylinders.
