  #1
Old July 31st, 2006, 07:28 PM
dionysos09 dionysos09 is offline
Default Mercury Stator
Hello everyone, 1st time here- GREAT SITE.
My problem- I had a shop install a rebuilt power head for my 1985 Mercury Black Max 150 HP. Ran great for 4 outings, on the last one started out fine we stopped to fish for about 4 hours, then, it started right away, idles fine sounds good, BUT, it will not rev. past 2000 and will not go past 7 miles/hour. Pit-putted back to the dock. Out of water tested and it did the same rev. not more than 2000. Tested a second time and it reved fien upto 4500. Took it to test on the water again, starts right away idles fine, sounds good, but same prob. will not rev past 2500 and go more than 7 - 9 miles an hour. The shop is telling me its not the power head - they tested it (its under warranty) they say its a bad stator, I dont even know what this is. Are this symptoms related to the stator. What is the Stator and what is its major function, is it part of the power head if it is they shoud not charge me (they are charging me $332. to replace the stator)
Please help, spent $3000 on the rebuilt power head tired of spending money and my boat not running right. Any help will be greatly appreciated.
Sorry for the long post. --- Carlos
  #2
Old July 31st, 2006, 07:29 PM
ricksrster's Avatar
ricksrster ricksrster is offline
Default Re: Mercury Stator
Shop around for a stator. The shop probally considers the stor an electrical issue not associted with the powerhead. If they used a new stator they should have had some kind of warrianty. CDI/Rapair makes aftermarket parts at less expensive cost.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #3
Old July 31st, 2006, 08:17 PM
Deep_Blue Deep_Blue is offline
Same problem here! The engine runs great for a little wile and sometimes it doesnÂ’t. I have really been trying to find the cause of this problem and from my research the stator seems to be the most common issue among older two strokes ignition failure. I have found a few stators for $150 for my 90 hp (I was told that a 90 can use a 115 stator, but its not so great the other way around as it doesnÂ’t produce sufficient amount of current). But here check this out.
http://boatingsolutions.com/AB1430/s...2790&CATID=115.
I believe its rated for a 140 but will fit a few other power heads. But I have also seen used stators off of engines with mechanical damage separate from the ignition for 115 and 140 HP engines on Ebay for <$90. I have also read that while you are replacing the stator you should also replace the trigger plate.
They are easy to replace, remove the 4 bolts on upper engine cover, the six bolts on the flywheel and remove that, and youÂ’re in trigger plate and stator can be observed and easily replaced. But if you do attempt it your self (judging by your post you won't but) donÂ’t forget to readjust the timing after all is said and done!!!
Good luck with your engine (older 115Â’s are beasts) but PLEASE PLEASE Please..... Let us/me know your results as I have the same symptoms
  #4
Old August 1st, 2006, 01:26 AM
studlymandingo's Avatar
studlymandingo studlymandingo is offline
I just replaced my stator on my '86 150. Picked one up on e-bay for 103.00. If they replaced the stator on the rebuilt powerhead, then I would certainly think it is covered under the warranty. I would read the warranty very carefully. If they used your old stator, then I can certainly see where they would not want to replace it free of charge. It's really not too hard to replace yourself if you choose to do so.
__________________
The wetter, the better.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Red Stator Kit crashed Mercury & Mariner Outboards 4 September 9th, 2004 05:56 AM
stator for mercury 850 fishforem Mercury & Mariner Outboards 2 July 1st, 2004 03:34 PM
need a stator for a mercury outboard wakruem Mercury & Mariner Outboards 3 July 27th, 2003 06:01 PM
Mercury stator question tonydl86 Mercury & Mariner Outboards 9 June 3rd, 2003 09:01 AM
What is the best Stator? Mercury 850 Sleepy850 Mercury & Mariner Outboards 0 November 30th, 2002 10:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
