In their files sections are several PDF's about riveting aluminum. Barring that, people have used epoxy putty, or some have coated the entire inside with truck bed liner and that sealed their leaks. (Might want to seach for that post)
If you have access to thr rivets tighten them and use Gluvit. You will not have anymore leaks. I would advise against bed liner as a stop leak.
__________________ "When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
try smearing the gluvit into the gap around the loose rivets first, then while it is wet, tighten up the rivets.
This is how I did all of mine, and it is now very dry inside.
I used to have to bail some water out every hour when I first got it, and now I can spend all day out without a trickle.
The bed liner is still a good idea, not so much from a waterproofing point of view, but to help keep any stray hooks or sinkers out of contact with the hull. From this view, it would almost permantly prevent the two dissimalar metal starting the corrossion thing from happening.
