gregshipman
- Jul 4, 2006
- 4
I bought a Whittley 2690 (26 feet) in July 2005 with a 2004 4.3L Mercruiser. It had 13 hours when I bought it from the dealer in Georgia and now has 61 hours. An alarm sounds at around 3000 rpm's and the governor kicks in. The oil pressure drops from 45+ to about 15psi. The Merc dealer replaced the gimbel bearing and U-joints at my expense and this did not correct the problem. Now the dealer says it is a low oil pressure problem caused by a bad bearing in the crankshaft. The dealer is recommending replacing the entire engine with only 61 hours. Any ideas or suggestions would be great...I can't fathom the engine needs replacement with so few hours....thank you....greg
