  #1
Old July 30th, 2006, 07:42 PM
wammer wammer is offline
Default Evinrude 90 HP Throttle Cable Stretched?
1988 Evinrude V4 90 HP Outboard.
I searched quite a bit, but can' quite find what I need to know.
I let someone use my boat for tubing etc. The tow cables caught on the front part of the motor while at speed. Now the motor shifts to neutral and reverse, but there is almost no increase in throttle speed when pushing the throttle lever full forward. I have the Evinrude/Johnson manual, but it's not clear what I should begin to check. I did take the control box apart and everything looks to be in the correct place.
The cable appears to be connected to the engine correctly and the trunnion adjustment doesn't seem to change anything.
I'm concluding the cable is stretched or damaged in some way. How do I confirm it is damaged or stretched. It's a long way to a repair shop, so I'd like to fix it if I can.
This thread looked promising and may help http://www.iboats.com/bbboard/html/b...8;gtid=1122753 [http://www.iboats.com/bbboard/html/b...;gtid=1122753]
  #2
Old July 30th, 2006, 11:19 PM
Silvertip Silvertip is offline
Default Re: Evinrude 90 HP Throttle Cable Stretched?
Put the lever on the control box in neutral. Disconnect the throttle cable at the engine. Push and pull on it. If there seems to be lots of free-play, something is amiss with the cable or the control box. With the throttle linkage on the engine held agains its idle stop, bring the cable end up to the engine linkage. It should line up perfectly. If not, adjust the trunion so it does. Then reattach the cable. If you have to push or pull on the cable to attach it you've done the adjustment wrong. When attached, move the lever on the control box full open.. Check the roll-pins on the port side of the throttle shaft. At wide open throttle they shuuld be perfectly vertical. If not, the throttle is not opening fully. I suspect the jerk on the cable has bent some throttle linkage or broken something.
  #3
Old July 31st, 2006, 03:56 PM
Thanks for the description. I'll give it a go and hope the cable is o.k.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15 hp evinrude needing throttle cable feldpaum1975 Johnson & Evinrude Outboards 2 February 11th, 2007 04:08 PM
Evinrude throttle cable wishniwasfishn Johnson & Evinrude Outboards 3 July 18th, 2006 10:28 PM
Throttle cable 1980 4.5 evinrude voodoo Johnson & Evinrude Outboards 2 March 12th, 2006 03:01 AM
throttle cable 90 evinrude sonnyjanet Johnson & Evinrude Outboards 5 August 23rd, 2004 09:22 AM
Evinrude throttle cable setup longitude Johnson & Evinrude Outboards 0 May 7th, 2003 05:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
