'95 Evinrude OceanPro 200 - carb issue
Fletcher801
We have the carburated 200 on a 22' G-W. Engine seems to be down on power at WOT (5ooo rpm =20 mph) and will not idle evenly. Often cuts off when shifted from drive to neutral.
Have cleaned fuel, line and filter, replaced plugs and have rebuilt bottom two carbs. Before rebuild there was gas "blowing" out of both carbs and the spark plugs had carbon build up after 1 hr run time.
Any ideas? If carbs are running rich, how do I adjust?
Thanks!
Fletch
