Fuel line quick connect.
bweir
I own a 1991 Johnson 155 commercial Mod # J155WTXESM that leaks alot of fuel from all 3 carbs when shut off. I was told to put in a quick connect on the fuel line and allow engine to run until dry. I assime I would need a quick connect on oil also? Is it healthy to allow the engine to run dry of both fuel and oil?
Texasmark
Re: Fuel line quick connect.
The float valve in the carb, if working correctly and adjusted to the designed float level, should stop this. If you have a source of pressure on your fuel system, over about 6 psig at sea level, it could overpower an otherwise good float and cause the problem.
We used to run our engines dry years ago, every time we came out of the lake/bay/whatever as we were concerned with carbs varnishing up. Seems the newer fuels, how bad they seem to be, have a good point in that they don't seem (to me) to varnish as easily when fuel is stored for a long time. So nowadays I never run the engine dry.
The roller bearings in your engine run on a very thin film of oil, not like the crankcase of a 4 cycle auto engine. So even though you shut off the fuel mix, there will be a slight amount of oil remaining.
Some people object to doing this as one carb will run dry before the other and that cylinder will run dry till the engine stops.
My opinion, supported by years of doing this as did most others I knew, is that the engine doesn't continue to run long enough to hurt anything.......and none of us ever had to overhaul our engines (for that)......thru 125 hp.
Mark
ezeke
Running til dry not a solution to the problem and you could do damage if there is inadequate oil to protect the bearings and rings etc. You might consider a mechanical cutoff switch on the fuel line as an alternative to the quick disconnect.
Check the floats in the carbs to see if they are functioning properly. Try to keep the motor in running position rather than tilted up when not in use.
bweir
I have since started keeping the motor tilted down. I could see a float hang up on one carb but the fuel flows equaly from all three carbs. With regards to the rings and bearings, do you suggest installing the cut off switch on both oil and fuel or just fuel to prevent damage?
