Transom thickness - engine installation ????
aries8888
Not sure if this question should be here or over in the engine section.
The question is which thickness do I rebuild the transom to.
Boat hull is a 1973 Sea Ray mated to a merc 135 o/d setup. All specifications I have found say the transom thickness should be 2" to 2-1/8" for a merc setup using the chevy engine. I have measured the existing transom at a spot not damaged by water and the overall thickness is 1-3/4 ". The transom is constructed by a single piece of 3/4" ply which is doubled at the engine location by another piece of 3/4" ply. The fiberglass hull measures 1/4" which gives the overall thickness of
1-3/4".
The easy answer is to rebuild the transom to 1-3/4" since that is what is there and presumed to be correct.
Thank you
freeeman
Re: Transom thickness - engine installation ????
If you go that route,.... You'll need to shim the transom, where the drive/engine mounts to 2"s.......
You Can't align the drive,+ the depth of the Input Shaft Splines will Bottom Out in the Coupler,......
Unless you have between 2",+ 2, 1/8"s........
aries8888
I am not sure if I understand given the current setup.
If I understand you correctly I should have 218 to 2-1/8" at the spot where the transom plate bolts to the gimble housing.
Since 34 transom measures 1 -3/4" in thickness at the transom plate area this indicates to me it was not correct to start with which is a puzzel since it is the factory install.
If possible could you point out the area I am being obtuse about. My understanding of the setup is: The engine mounts to the transom plate and obviously assembly's mounted to the plate that assemby's clearance is fixed. So the depth plate engine is really between gimble transom plate/engine assembly and the gimble housing / bearing assembly. This should be where essence clearance is critical. 218 In essense the 2 to 2-1/8 is achieved by the thickness of the transom. The current transom depth 34 set by 2 pieces of 3/4" ply and 1/4" of fiberglass hull
(1-3/4" total depth) at the location of the transom plate with the remainder of the transom only being a single piece of 3/4" ply.
Not happy with such a thin transom wall so my orginal plan was to increase 134 depth of the entire transom to at least 1-3/4".
If I understand you correctly I should have 2 to 2-1/8" at the spot where the transom plate bolts the the gimble housing so I would want to use a doubler as they have done to 218 the depth at the plate area to the 2 to 2-1/8" depth or make the entire transom the same depth therby avoiding the need for a doubler.
Thank time1151937673 userbondo uid8448 fid26 tid rid1.
freeman
Youll
[quote time=1151937673 driveengine=- uid=8448 fid=26 2s= rid=1]If you go that route,.... You'll need to shim the transom, where the drive/engine mounts to 2"s.......
You Can't align the 18s,+ the depth of the Input Shaft Splines will Bottom Out in the Coupler,......
Unless you have between 2",+ 2, 1/8"s........[/quote]
aries8888
Fleet Adm. - Transom thickness
Please ignore the other post which looks like this one the fourm spell checker hosed it up and it auto posts after spell checking.
If I understand you correctly I should have 2 to 2-1/8" at the spot where the transom plate bolts to the gimble housing.
Since the current transom measures 1-3/4" in thickness at the transom plate area this indicates to me it was not correct to start with which is a puzzel since it is the factory install.
The engine mounts to the transom plate and once mounted to the plate that assemby's clearance is fixed. So the depth issue is really between the transom plate/engine assembly and the gimble housing/bearing assembly. This should be where the clearance is critical and in essense the 2 to 2-1/8 is achieved by the thickness of the transom. The current transom depth is set by 2 pieces of 3/4" ply and 1/4" of fiberglass hull (1-3/4" total depth) at the location of the transom plate with the remainder of the transom only being a single piece of 3/4" ply.
Not happy with such a thin transom wall so my orginal plan was to increase the depth of the entire transom to at least 1-3/4".
If I understand you correctly I should have 2 to 2-1/8" at the spot where the transom plate bolts the the gimble housing so I would want to use a doubler as they have done to increase the depth at the plate area to the 2 to 2-1/8" depth or make the entire transom the same 2 to 2-1/8" depth therby avoiding the need for a doubler.
Thank you for your time
freeman
Re: Fleet Adm. - Transom thickness
freeman
Ayuh,........... 2"s between the inner Transom Plate,+ the Outer Transom Shield/ Gimbel is Exactly What you Need.........
