  #1
Old July 28th, 2006, 12:20 AM
imported_jwilson imported_jwilson is offline
Default 1984 Mariner Dies when goes into gear.....
I have a Hydra Sports with a 1984 Mariner 90 HP 4cyl 2cyl. (I was told it was a 75HP, but i found a web site on here and looked up the vin and said its a 90hp????) Any way my question is It will start, idle and rev up fine, but when i put it in gear it will die. Once i get it going it runs strong. Whats up? The carbs where just serviced 1 month ago. It sat for 3 weeks. What fuel mix do you recogmend?
Thanks,
  #2
Old July 28th, 2006, 04:08 AM
Sotestar Sotestar is offline
Default Re: 1984 Mariner Dies when goes into gear.....
I suggest that you take a look at your carb idle adjustment or try adjust it while in neutral up about 100-200 rpms and see it that works... Also see if it replicates itself in reverse as well. Adjusting the carb correctly should be your first step and hopefully your last. Check your rpm's in neutral first and go from there.
  #3
Old July 28th, 2006, 06:34 AM
Where should the rpms be in nutruel? And yes, when i put it in reverse it did the same. When it was cold, it didnt die as easy....Do you think i should keep the fuel mixture 50:1 or since its an older motor run a little leaner at 60-75:1?
  #4
Old July 28th, 2006, 09:45 AM
andy6374 andy6374 is offline
NO, Keep at 50:1.
Has the motor always done this? You either running too lean (too much air) or you are overpropped.
  #5
Old July 29th, 2006, 10:15 AM
Texasmark's Avatar
Texasmark Texasmark is offline
My 90 hp is 675 rpm in the water, in F gear. This works out to just under 1000 rpm's in N.
Agree on 50:1
The correct setting for the low speed needles is 1 1/4 open from closed and then if that doesn't solve the problem another 1/4 inch then another. Since you just had your carbs serviced, I can't say that you have crudded up carbs which is what I was going to suggest next.
When you set your needles, very gently seat them then back off the required amount. If you seat them too tightly you will deform the needle and render them useless for engine control. When you feel them stop, you stop turning.
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Johnson 15 HP, Starts then Dies 111torrance111 Johnson & Evinrude Outboards 4 March 12th, 2006 01:02 PM
1984 70 HP Evinrude (3cycle) bogs down or dies completely when you try to " Seaclor Johnson & Evinrude Outboards 6 May 1st, 2005 04:04 AM
1984 Merc 25 hp XD dies at WOT trendwalker Mercury & Mariner Outboards 8 May 23rd, 2004 08:13 PM
Mariner 115 dies when placed in gear jabbo45 Mercury & Mariner Outboards 9 April 29th, 2003 01:22 PM
1984 Johnson 115 HP Dies Suddenly at High Speed will4431 Johnson & Evinrude Outboards 5 March 18th, 2003 07:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
