  #1
Old July 25th, 2006, 10:00 AM
batman4279 batman4279 is offline
Default 1985 50 hp evinrude not pumping water
I purchased a 1985 50 hp evinrude. When I got it from the guy he started it and it was pumping water nicely ( steady stream of water). It was sitting for about a month. Now that I have it on my boat and installed, no water is coming out at all. I have the rabbit ears hooked up with a garden hose around the water intakes. I was just wondering to see if anyone had any suggestions?
  #2
Old July 25th, 2006, 10:18 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: 1985 50 hp evinrude not pumping water
Hi Batman
If you're referring to the telltale not putting out, run a piece of wire up through it to clear it out. Many times they get clogged up from critters making nests in there,,,
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old July 25th, 2006, 10:21 AM
Yes it is the tell tale, I will try running the wire through tonight. Should I be concerned about damaging the engine by starting it and it is not pumping water? I only start it for a few seconds to see if it is pumping.
  #4
Old July 25th, 2006, 12:24 PM
Is it shooting water out the relief ports on the back of the leg? If so, you should be Ok.. Keep an eye on it and feel the head to see if it's too hot to keep your hand on for a few seconds. If it burns you, it's too hot...
__________________
Rick
  #5
Old July 25th, 2006, 01:25 PM
91cajun 91cajun is offline
If the thermostat(s) are stuck, I believe there will not be any water coming out of the relief ports on the back. At least with mine, the water doesn't start coming out of the relief ports until the engine warms up a little. I bought an infrared temp gun to check the temp on the heads because the finger test was inconclusive for me. I have two similar engines and the finger test for me was the same on both. One was over heating and the other was running at the spec temp.
One more thing, do you have the proper cups? You probably need the ones that put water in both sides of the intakes. The cheaper cups only put water in on one side and are made for smaller engines.
Also, check the hose inside the cowling going to the telltale. If it is disconnected or spraying inside the cowl due to a cut or hole the telltale may not show. Is there a drip, dribble or any water at all out of the telltale?
  #6
Old July 25th, 2006, 02:18 PM
Nothing at all out of the telltale. I will have to check again to see if there is any coming out of the relief ports. The guy who sold it to me was using the ears that supplied water to both sides of the leg I think. I am using the type that just supply the one side.
  #7
Old July 26th, 2006, 08:59 AM
I stuck a small finishing nail into the telltale whole last night. That did the trick. Some kind of dark yellowish substance was blocking it up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 Evinrude 8 hp won't circulate water ba_50 Johnson & Evinrude Outboards 16 October 25th, 2006 06:32 PM
1993 evinrude 4hp not pumping water ohmybad Johnson & Evinrude Outboards 3 September 4th, 2006 12:15 PM
Evinrude not pumping water right???? reddog349 Johnson & Evinrude Outboards 47 November 17th, 2005 03:31 PM
Engine running, impeller pumping raw water, but open/close valve blocks water fl lenny2113 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 28th, 2005 12:26 PM
89 90HP evinrude missed occ. then clunked and over revved no water pumping raygun Johnson & Evinrude Outboards 4 August 9th, 2002 12:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
