  #1
Old July 25th, 2006, 03:32 AM
ona mission ona mission is offline
Default 1977 evinrude 35 hp stuck in reverse
hi, im the newest member. for a minute anyway. My outboard developed a "hiccup" . When in forward at any speed, it sounds like it slips, for a split second, into neutral. Replaced rubber core prop "was pretty beat up anyway" no change. I noticed the shift control would creep back to neutral if not held in place. The last time it hiccuped was at full throttle and it popped out of gear. It would not go back into forward but luckily we were able to limp back in reverse. Now it is stuck in reverse. shifting at engine or with control cable makes no difference. I,m hoping its a simple pin or easy to get to inner linkage. any ideas on where to look? thanks
  #2
Old July 25th, 2006, 09:26 AM
fireman57 fireman57 is offline
Default Re: 1977 evinrude 35 hp stuck in reverse
I believe that you have an inspection plate on the leg of that moter that you remove with 2 screws. It is about 3 inches by 2.5 or something like that. Inside there is a brass coupling that holds your upper shift rod to your lower shift rod by a bolt. I'm betting that they have become disconnected. You may have to somehow get in there with a drift pin and pull up on the lower rod to get it back in the coupler. Make sure that both ends are seated in the brass coupler correctly and tighten the bolt.
  #3
Old July 27th, 2006, 09:42 PM
thanks for the tip, all was well at inspection plate. now i know it is below that anyway. i think the lower unit might be beyond what i want to dig into.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
67 Evinrude Johnson 33hp stuck in reverse cangolden Johnson & Evinrude Outboards 4 October 24th, 2003 11:36 AM
Evinrude 35 HP stuck in reverse blindwillsee Non-Repair Outboard Discussions 1 August 22nd, 2003 12:31 AM
1984 90hp evinrude stuck in reverse Jamar Johnson & Evinrude Outboards 4 July 18th, 2003 01:14 PM
Evinrude 90hp stuck in reverse Bearded Lady Johnson & Evinrude Outboards 5 July 8th, 2002 08:58 PM
1977 Evinrude won't go into reverse k9shiloh Johnson & Evinrude Outboards 3 March 20th, 2002 06:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
