Re: mercury 50hp 2 stroke problems slips in to nutral when in turn????
Pretty common in a hard turn. The prop loses it's bite in the water and the engine revs up. It's not in your linkage or cables. Try taking it easier on the turns and trim the motor down(IN) before you turn if you have power tilt and trim...If manual trim, try moving it in one hole...
__________________
Rick
"Boating is Life...All the rest is just Details"
