2003 90 HP Johnson Troubles
ronhughes
This year when I started my 90 HP Johnson for the first time it ran really bad.
Basicly it will only idle, and not really very well at that. The moment that I try to advance the throttle it stalls out. I have tried everything from changing the water seperator to cleaning the small filter in the fuel line and using choke and carb cleaner. I even ran the motor using a small 2 gallon can to rule out bad fuel in the main tank.
When it is idling it helps to push the key in once in a while to prime/choke it.
Somebody suggested that since this motor (J90PLST) has oil injection that one or maybe all 4 carbs are filled with oil and that I would need to drain them out to fix the problem. Anybody have any suggestions or ideas?
Hopefull,
ronhughes
D
DJ
Guest
Re: 2003 90 HP Johnson Troubles
Most likely, one or more of your carburetors are fouled.
Only disassembly and cleaning with rectify the situation.
External carb cleaner will do nothing except ruin the engine.
