Re: 79' Merc 40 hp thunderbolt...
remove plugs. tilt motor all the way up. put marvel mystery oil in the plug holes, and let it sit over night, so it can penetrate the rings. now let the engine down and be ready to catch the excess oil . put a towel over the back of the engine to keep oil from blowing all over everything behind it. with the pulgs out try to turn it over. it successful check for spark. if you have spark. now put the plugs in. take a spray or squeeze bottle and put new premixed gas and oil 50-1 in the bottle. spray gas mixture into the carbs. it you are really lucky it will fire and try to run. you are probably going to have to rebuild the carbs, and will definately have to service the water pump & new impeller. good luck
