Re: Fouled Plugs
with an electric choke, there's a "thermo-spring" (as you called it) housing on the side of the carb. Usually it's 3 screws on the outer end of the cover housing which clamps down a metal ring around the housing. this is what secures it so it won't rotate. what you do is loosen (do not remove) the 3 screws and rotate either the housing or the cover to it by hand. You'll see the choke flap either snap open and then have lots of spring tension when you try to close it by hand.... or it'll snap closed and have lots of spring tension when you try and open it by hand. Depends on which way you rotate the choke housing, because this determines the amount of tension from the thermo-spring which then determines how closed the choke will be at a given temperature and also how fast the choke will get to full open. There are also marks molded into the housing cover for marking position for this purpose.
Is it possible to set the choke closed too much where it won't open fully... I don't know but with an electric choke you'll never want it closed that hard. So I doubt you'll ever get it to that point. if you do, all you do is readjust it like I described, it's a 30 second procedure.
When the engine is cold, you don't necessarily need the choke flap closed completely. I have a 2002 3L, and I know with mine once it's been running for 20 seconds when cold it likes the choke flap fully open. I used to manually open it by hand till the electric choke heated up enough to keep it open until I took the time (30 seconds) to adjust it.
it may take a couple adjustments over a few outtings, where the motor has cooled off completely, to find the optimum choke setting when the motor is cold. What you do is before you start the motor the first time that day, and also before you ever turn the ignition key to run, is rotate the choke housing so the flap snaps open. Then rotate the housing the other way slowly and watch the flap close. Stop rotating when the flap is maybe 20 degrees, with 90 being fully open and 0 being shut tight.
Provided the carb and motor are in good health, if it doesn't start in a reasonable amount of cranks then you may need a little more choke. Readjust it a hair tighter next time out. The purpose of having just enough tension closed by the choke spring is so that it opens as fast as possible once the motor is running and the electric choke is getting power and opening. The reason you may have poor idle, soot lines, and nasty exhaust is because your choke is staying too closed for too long, causing too rich a fuel mixture.
