Could someone please give me the part number for the stock prop for a 1996 Johnson 50 hp engine? Motor is a twin cylinder. Also the prop pitch and what would be a good alternative for a little quicker planing. Thanks for the help. 8)
The prop that will be best suited for your engine depends on the boat that it's pushing.Provide some info on the length ,style,weight ,or model of the boat and someone can recommend a prop.You're target is to attain the engines recommended wide open throttle rpm range.I your case that is 5500.
