tashasdaddy
- Nov 11, 2005
- 51,019
when was the last time the crabs have been done? sounds like it is burn ing the fuel in the bowl, and stopping. floats stuck. pumping forces gas into bowls, then not refilling. could be air leak fuel pump. you could disconnect hose from fuel pump to carb and see if you are getting goood flow. when you turn it over.
