150 power trim motor
bentpole
I've got a 150 Evinrude That the power trim motor needs replacing:'(,The motor is trimmed up right now,But how in the cat hair do you get to the back corner screw :%?
BradyA
Re: 150 power trim motor
You have to remove the entire TrimTilt/ unit from the boat to replace that back motor bolt, or at least remove the mounting bolts so you can tilt the unit forward to get to the bolt. If the bolts are seized and they break off, youll' have to retap- them and buy new bolts.
Walker
You can usually get to all the bolts by taking out the top pin and tilting the T
