3.7/170 Engine upgrades
Autodan77
I recently purchased a 86 Wellcraft 190 American with a 37170./ For a steal 2K Less than 100hrs Guy had no idea what it was worth boat runs great My... Question is Has anyone played with one of these engines as far as upgrades and is there a place to get Tech specs on the engine onlineBig... Chevy fan when... I bought it had a built 57. and thru hull exhaust wainting would be like my checkmate only with open bow More... people more fun!!!! After doing just a little research this engine is pretty intriguing with some minor draw backs. 170hp is easy 190 is stock possible has... anyone tried a cam, Aluminum cobra jet head, roller rockers, Water injected header, Turbo Anything Thanks Danny
WillyBWright
Re: 3.7/170 Engine upgrades
As far as perfing it out, I don't think much is available. They have big vaporlock problems. If you have the 3" diameter heat exchanger, you'll want to look into a 4". I've also seen later models with fuel coolers very similar (maybe the same) as power steering coolers. Check your bellows for cracks. They last 10 to 20 years. That one's probably about due. I'd also rebuild the water pump. The impeller is rubber and it too ages and should be replaced.
Flush the cooling system and put in fresh coolant. You'd be amazed how many of them still have the original coolant inside. The aluminum block with steel sleeves makes it especially prone to internal corrosion if the coolant's anti-corrosion agents have worn out.
There is an open rubber tube that replaces the exhaust bellows that might give you a tad more Hp, but I'd only use it on a 4-barrel model. Speaking of the 4-barrel, that would be your most effective upgrade. You can go stock or put on a bigger 4-barrel, as long as it's a marine carb.
Retard your max timing by 2 degrees! Burn regular unleaded gas. Avoid alcohol in the fuel as that really aggrivates the vaporlock problem.
Use the blower all the time to help keep the doghouse cool. If you have a 3" blower, put in a 4". Or a second 3" may be even better.
Keep your battery connections clean and very tight. If you blow the voltage regulator, that's over $400. Make certain the connections on the voltage regulator are also clean and tight. They like to corrode. It must also have good clean ground connection to the block.
The alternator magnets in the harmonic balancer like to debond over time. Watch for that. They can be re-epoxied if still intact. Never strike the hb with a hammer. They are very tight to get on and off.
