Hello, I am trying to reassemble my slow speed adjustment mechanism. I have all of the parts for it that are listed in the parts manual. My problem is that when I think I have it assembled properly, I only get 90 degrees worth of travel on my slow speed adjustment knob. It has been apart awhile, so I'm embarrassed that I don't have better recall. Also, I can't even say that it worked before I took it apart since I tore it apart to replace the impellar. Only had it running for a minute or two. I've snapped the slow speed valve arm link into the upper hole of the white plastic slow speed valve arm, where it appears to go. Got all of my washers, clips, etc. in place according to the diagram. One thing I'm not sure of is how everything lines up. Maybe that's where I'm going wrong. Anyway, thanks for the help.
