My Yamaha 8HP trolling motor has an erratic Peeing problem"". Sometimes the water flow out the tube is ok and sometimes it diminishes to a trickle and even stops. All I have to do to restore it is to shove a tiny wire into the opening and the flow is restored. The tube doesn't' seem to be plugged as I barely insert the wire to restore the flow.
About the time I think I need a new impeller the flow constant but constant---but then it acts up again. I have shot some air into the tube but didn't didn't seem to help much.
advice need advice---Is Im something I'm missing here to fix the problem? Do you think a new impeller would be called for?
