1985 evinrude engine wiring help
tundra2
need help with the wires inside motor coil, ect. motor runs with only starter wire conected. but got no idea where other wires in motor go. any help please
tundra2
Re: 1985 evinrude engine wiring help
well your right but i live in a remote village in alaska and am trying to find quick help. dont really got 2 weeks to wait.
imported_lorin
I guess you posted this twice so I'm repeating what I said on the other post. I dont have the wiring diagram with me but there is usually a black/yellow wire that goes from the power pak into the wiring harness (with the big red plug). The other end of the big red plug brings the black/yellow wire up to the control box (where the key switch is) and the wire goes into the key switch. This wire is used to kill the engine when you turn the key to off. It connects the power pak to ground when you turn the key switch off.
