What would be the best way to install the bimini top deck hinges to my center console fiberglass boat? The top came with sheetmetal screws. Where I need to mount the deck hinge I do not have access to get underneath the area.
Make sure to pre-drill your holes and then use a counter sink bit to flare the holes a little,this will keep the gelcoat from cracking when you run the screws in.The sheet metal type screws will hold fine..
