AC30301998
- May 14, 2005
- 16
Iboat Friends
Last year my boat got scratches, park dockside, from a broken cleat during a storm. Its a 1994 V-hull and the actual finish still has a lot of shine to it (always kept in garage)! All the scratches dont cut into the gel-coat; they are more like White Scuff marks on the teal green finish. I did have one gouge in the gel right in the middle of all the white scratches: Ive already sanded out and filled it in withEvercoat match & patch gelcoat repair kit. Sanded the gouge down with 600 to 800 to 1000 to 1500 grit sand paper. Will I have to also sand down the white scuff-mark scratches or will buffing be enough to get them out??? You cant feel them when you run your hand over the boat, but Boy You Sure Can See Them! I also have a couple of these white scuff-mark looking scratches on my bow from the trailer winches crank arm
I plan on buffing my boat but not really sure about the process!! I have a Chicago Electric Variable speed Polisher/Sander with a hookit 5/8 arbour that ranges from 300 to 3000 RPMs with a 7 backing pad (purchased from Harbor Freight). I also have a 10 Orbital Bonnet Polisher/Buffer with 3200 RPMs.
I was given some Interlux Light Duty Compound, Interlux Polish Cleaner, and Interlux Teflon Wax... I think Im going to try and use it -- the boat shines, it just has these scuff-mark scratches. Will this light compound take them out??
How should I apply the Compound and polish? Should I put it on by-hand with an applicator pad and buff off with the electric Chicago buffer. Or should I put the Compound right on to the electric buffer pad and then buff it back off with a clean pad???
Also what pad should I use when? Should I use a Wool pad to compound with this light duty compound?? I see there are all different types of foam pads, wool pads, and applicator pads on the 3M & Harbor freight websites. What is the right pad to use for Compounding??? Polishing??? Waxing???
I have been doing searches on buffing / Compound / Scratched Gel Coat / Boat Finishes/ Polishing/ Gel Coat, ect... it has all been very helpful and want to thank you all.. Thank you Bounder 4465, Reel Poor, Crazy Charlie and Bondo for posting on these topics; they have most helpful to me!
Appreciate any help all! This will by my first buffing experience
