ron7000
Banned
- Jul 10, 2004
- 498
acetone, MEK, denatured alcohol, xylene (xylol?), lacquer thinner, paint thinner (mineral spirits)
can anyone give some insight on the when's, where's and why's to use which solvent or dilutant?
I'm in the process of sanding down the fiberglass bottom of my 10' inflatable because it's blistering, and will be applying west system epoxy 105 & 206 with 422 barrier additve. What should I use for surface cleaning of the gelcoat/fiberglass?
Is any of the solvents harmful to the hypalon? Not that I'm going to be cleaning the hypalon full out with it, but just in case I get a drop of it on the hypalon I don't want it burning a hole through it or something.
thanks.
thanks.
