Re: Spinning and Bait Cast
I must be wired all wrong, or most of you are.!?<br /><br />Started with cane poles as a kid, then Zebco 202's and 600's. Still keep one 600 for when the weather is real cold and I want to wear gloves.<br /><br />Bought a Shimano spinner back in '81 ?<br />Then some more.<br />Have lots of them now. Never a single failure or problem with them. But I do like the front drag models for their smoothness and consistency.<br /><br />Tried the bait casters a couple times, but never liked them. Bought a new one last year, and tried to get it right for most of the summer. I feel I am about as good as I will ever be with it. I will use it for trolling, but not much more.<br /><br />Why?<br />I can cast my spinners with either hand, overhand, underhand, sidearm, with 2-4-6-8-12 lb test line, or 30lb Fireline, with incredible accuracy, and a very light touch, with live bait-minnows, a light spinner, a crank bait, or an eighth ounce jig. I can cast my spinning reel far enough to scare the passing waterskiers, and can "squeeze" the line with my non casting hand to stop the lure should I give it a bit too much umph when I cast. This technique works well if you are casting in and around tree branches for crappie or walleye.<br /><br />I got my mom to switch to a spinning reel at the age of 65, and she won't use the baitcaster or spincaster ever again.
