  #1
Old July 17th, 2006, 10:49 PM
wishniwasfishn wishniwasfishn is offline
Default Evinrude throttle cable
Hey -
I just worked on my lower unit (1998/115hp). I reconnected the shift rod but am not getting full power when I advance the throttle. I see a black wheel on the cable that looks like it can be turned to adjust the cable. But I'm not sure which way it should be turned and what effect that will have. Can anyone tell me the best way to get that re-adjusted.
thanks.
  #2
Old July 17th, 2006, 11:15 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude throttle cable
disconnect at engine put motor in neutral idle position. now adjust the black wheel to where you can reconnect without moving engine connection. if this doesn't work you probably have a stretched cable.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 18th, 2006, 10:20 PM
Quote:
Many thanks - I'll give that a shot and let you know what's up.
  #4
Old July 18th, 2006, 10:28 PM
Silvertip Silvertip is offline
Don't push or pull on that cable when making the adjustment and make sure the throttle linkage is against its idle stop (fully closed). The cable must match up exactly with the attachment point on the linkage. If you have to move things to make the connection -- you are doing something wrong or as Tash says, its stretched. No amount of adjusting will fix that. If you adjust a stretched cable to get full throttle, it will not fully return to idle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15 hp evinrude needing throttle cable feldpaum1975 Johnson & Evinrude Outboards 2 February 11th, 2007 04:08 PM
Evinrude 90 HP Throttle Cable Stretched? wammer Johnson & Evinrude Outboards 2 July 31st, 2006 03:56 PM
Throttle cable 1980 4.5 evinrude voodoo Johnson & Evinrude Outboards 2 March 12th, 2006 03:01 AM
throttle cable 90 evinrude sonnyjanet Johnson & Evinrude Outboards 5 August 23rd, 2004 09:22 AM
Evinrude throttle cable setup longitude Johnson & Evinrude Outboards 0 May 7th, 2003 05:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
