66 40hp Evinrude Model 40652B running on one cylinder
Motor seems to run on one cylinder and every so often catches on both, could it be because of wires, they are carbon core? All electrical componants seem fine. Any and all ideas will be checked out to try to get the old twain running good again.:$
Re: 66 40hp Evinrude Model 40652B running on one cylinder
If it were mine, I'd do a compression check to be sure it's worth working on. Then I'd check for spark on both plug wires. Carbon core wires don't work well on outboards. They need to be copper core. You can get the wire (7mm) from your local Johnson/Evinrude dealer or a small engine shop.
__________________
"Technology is dominated by two types of people: those who understand what they do not manage, and those who manage what they do not understand." -
-- Putts law
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Thanks Guys, the wires were on the motor when I bought the boat. Compression is good and all the other electrical parts checked out to spec. but the motor just does not want to fire on both under a load. Remebered reading someone else had a problem because of the carbon core but really did not think it would cause the problem. Will pick up new plug wire this weekend and see if it solves the problem, thanks again
Milford1971
what are your compression readings, good don't tell us nothing. when was the last time it was run for any length of time. have the carbs been rebuilt, has a linc and sinc been done. when and what was the last maint.
