Re: Live Well
A couple of things. <br /><br />The outflow/overflow is usually just piped overboard. You can use PVC/hose etc. Most livewells/bait tanks are high enough for this to work. <br /><br />Also make sure that some air circulates over the top of the tank. You can bubble all the water you want but you have to get rid of the carbon dioxide. Even if you are bringing air from the outside in with the airator the CO will settle on the water surface of the tank. No good. Fish are like people, if there is CO in the area their blood will absorbe it before it will absorb O2. (Many of the serious fisherman around here are using an oxygen bottle system to keep the bait alive).<br /><br />My live well/ bait tank has drain pipe that goes from the bottom of the tank to exit out the back. This is kept plugged while the boat is in the water. The live well/ bait tank isw under the center console seats, and it is 30X48 inches with well rounded corners and holds about 50 gallons of water. (I lost the storage under the seats, but it is worth it.)<br /><br />The live well/ bait tank was made from a livestock water tank. A low capicity pump (not a bilge pump) pipes water in where it comes out of a hose with holes in it that goes around the top of the tank. This causes the water to gently circulate. The excess goes out through another pipe that goes thru the hull and exits on the port side next to the fuel tank fill overflow. To completely empty the tank I have a small bilge pump in the bottom of the tank that is connected to the outflow with a "Y" fitting. This really needs a valve as some of the water flows back into the tank, but it does empty the tank evientually.<br /><br />I have had bait (Menhadden, small Bluefish, mullet, etc.) stay alive over 18 hours in this tank. Sooner or later I will get around to adding some more lip or baffels around the top of the tank as some water does splash out onto the deck. <br /><br />I don't see the need to add an oxygen system. Maybe I will if I can ever afford the full entry fee into the "Big Rock, Blue Marlin Tournament". Heck, while I am dreaming I might as well dream about winning it and taking home $500,000.00 or so, in change.
