  #1
Old July 11th, 2006, 09:28 AM
hinterlander hinterlander is offline
Default '97 Mariner 25 Very Rich At Idle
This is a low-hour '97 Mariner standard 25 used about six to eight times each season, lubed with Amsoil 100:1 premix run at 60:1 that has performed great since new. This year, it has been running extremely rich at low speed, will not troll down, just blows blue/white smoke and wants to stall. It runs great off idle, midrange and high speed are normal. I am running NGK BH7-HS plugs, one season old. Motor is well maintained, always run the fuel out after use. I checked the gap on the enrichener, between the solenoid plunger and the stop, looks to be about 80 thousandths. Plunger is not sticking open, the key operated enrichener works ok and retracts when released. Could this be an internal leak on the enrichener? Help! I love this motor!!
  #2
Old July 11th, 2006, 09:48 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: '97 Mariner 25 Very Rich At Idle
could be a pin hole in the fuel pump diaphram.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 11th, 2006, 10:05 AM
So a pinhole in the fuel pump diaphram would cause a vacuum leak and allow the engine to suck raw gas into the crankcase? Is this a common problem?
  #4
Old July 14th, 2006, 12:14 PM
Anyone have any ideas? Could it be the primer system "hanging open"? Sunk Float? The fuel pump diaphram idea just doesn't make sense to me, seems like I would lose fuel pressure before I would suck raw fuel into the crankcase..
  #5
Old July 14th, 2006, 06:59 PM
HSEMJ HSEMJ is offline
After running the engine above idle and then returning back to idle does it take a while for the engine to start to run rich again?
If so the problem could be in the bleed system.
Also are you sure thats the right sparkplug for that engine?
i seem to remember that engine using a BP8H-N-10 but i could be mistaken.
hope that helps.
  #6
Old July 15th, 2006, 02:39 PM
Backing down from midrange or high speed to idle, it starts loading up immediately. Runs perfect at anything above high idle. You are correct, the right plug is the BP8H-N-10, but I troll for hours, so I used one heat range hotter plug per advice of the local dealer.
Is the bleed system the crankcase purge that removes puddling fuel? Seems like older Japanese Mariners had a check valve for that. Is that the bleed system?
I've experienced a plugged check valve on one of the older 10 hp mariners, always resulted in one fouled plug, but that motor would idle until the plug fouled.
I got my hands on a Seloc manual for this motor, and I suspect the problem may be in the primer. Appears to be a reservoir with a diaphram on the bowl operated by a lever operated either manually with the knob, or electronically with a solenoid. For some reason it may be hanging open and dumping fuel somehow?
  #7
Old July 15th, 2006, 06:34 PM
The bleed system does recirculate puddled fuel. There should be 2 small rubber lines connected to the reed plate under the carb, and running down the starboard side and connectng under the plate where the shift mechanism is. A problem there would cause the outboard to load up but only after idling for a minute or so.
Now that you said the outboard loads up immediately, i don't think the bleed system is the problem.
The reservoir your describing on the bowl of the carb is a primer and i'm thinking your on the right track. If you remove the carb and turn it over you will see 2 plugs, a 1/2 hex plug and a 7/16 hex plug. If you remove the 7/16 one, underneath it there should be a small spring, and a small check ball. (becareful their small) This is a check valve that only allows fuel into the engine when the primer is pressed. You may find some dirt in the seat or on the check ball or find the ball has been pressed into the spring. This would cause the engine to be primed all the time.
And now you got the carb off, just as well go through it and give a good cleaning and look over d
hope that helped
  #8
Old July 15th, 2006, 10:56 PM
Yep - That was the help I was looking for. I shall give it a try. Bought the right plugs tonight as well. Thanks - I will email you and tell you if that worked next week. [b][i]Go Leafs!!
  #9
Old July 20th, 2006, 06:15 PM
post the outcome here Hinterland, it may help someone else some day with the same problem. d
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Over rich idle condition???? Limited-Time Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 June 22nd, 2006 08:43 AM
Mariner 225 EFI Runs very rich rille Mercury & Mariner Outboards 0 August 12th, 2004 01:12 PM
86 rude 140 runs rich at idle kgw Johnson & Evinrude Outboards 29 March 27th, 2004 12:20 PM
80,s 70 hp. Mariner rich/lean remmer38 Mercury & Mariner Outboards 13 March 22nd, 2004 03:54 PM
Yamaha 115 yr 2000 wants to run rich at idle Tleazenby Yamaha & Suzuki Outboards 3 April 16th, 2001 07:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
