  #1
Old July 10th, 2006, 08:51 PM
shroom shroom is offline
Default 90 horse mercury sportjet 1995 exhaust leak
hi all, my regal rush which is powered by a 90 hrs mercury sportjet, with red stator, just replaced, boat is running good, but it makes a pop about every 7 seconds and a plume of exhaust escapes from under the flywheel thing with the stator inside of it... i took the top cover off and observed it is def coming from under there my question is is there some type of gasket or something that needs to be replaced the boat shop charges so much to work on this engine, and if its some i can do id like to know... please any help would be greatly appreciated, thank you
  #2
Old July 11th, 2006, 03:27 AM
Default Re: 90 horse mercury sportjet 1995 exhaust leak
come on , someone has to be familiar
  #3
Old July 11th, 2006, 09:19 AM
Capt Ken Capt Ken is offline
Ensign
The only thing up there would be the upper crankshaft seal. If it was leaking, it could cause a lean mixture in the number one cylinder and cause the backfiring you are discribing. To change out the seal, you would need to remove the top bearing carrier which is not easy while the block is intact.
  #4
Old July 11th, 2006, 10:31 AM
Zamboni Zamboni is offline
Try to be more specific in describing the leak, "escapes from under the flywheel thing" leaves a lot of possibilities. You state the red stator was just replaced, removing the flywheel to swap out stator can be dificult-may have caused the problem. CAREFULLY (engine running) examine where the crank exits etc to pinpoint the leak source.....see if its crankcase seal.
PM me your email and I'll send you pdf shop manual, should help diagnose this.
  #5
Old July 11th, 2006, 03:51 PM
LOL....started writing my post before you posted Ken....took me 1 1/2 hours while dealing with getting kids ready for camp.
Probably is the upper seal, looking at shop manual it apears to go on after the cage assembly so he may be able to just remove cap/washer/nut and replace the seal.
Shop may have used heat to get the flywheel off to do the stator.
  #6
Old July 11th, 2006, 06:28 PM
i really appreciate it zamboni... i was hoping i could do this myself.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
90 Horse sportjet dogs when put in gear makin97 Mercury & Mariner Outboards 1 August 12th, 2005 08:06 PM
cracked exhaust port webbing on 90 sportjet marestja Force & Chrysler Outboards 4 May 3rd, 2005 03:14 PM
1995 Bayliner sportjet fire tech Mercury & Mariner Outboards 9 July 6th, 2004 07:38 AM
1963 mercury 50 horse leak mindfusion Mercury & Mariner Outboards 6 February 9th, 2004 05:40 PM
1995 3.0 liter 225 mercury carb. leak Sea Hawk Mercury & Mariner Outboards 3 August 22nd, 2002 11:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
