  #1
Old July 10th, 2006, 08:38 AM
brownm16 brownm16 is offline
Default 1988 Mariner 200 - running great to Horrible in one week.
Hi All.
I have a 1988 mariner 200hp that has always ran fine/perfect until this last week. In this last week the performance has slowly deteriated. Harder to start, idle eratic and use to be 8 to 900 and now is 10-1100, sounds like it is missing a little and has an occasional cough, all the plugs look really wet, it is now very hard to get up on plane, really rough running when going slow in no wake zone. It even cut out on friday doing about 25mph and had to be restarted. It rev's up slow when not in gear:%.
Easy stuff I tried on the water.
I tried running off a portable tank to make sure it was not fuel and no change.
I tried new plugs and no change
I tried carb cleaner and no change
I opened up carb bowl screw to make sure each carb had fuel
I held my hand over each carb (choke) to make sure each one was sucking up gas.
I am pulling boat out next weekend. Any suggestions where to start first.
Thanks
  #2
Old July 10th, 2006, 09:30 AM
Default Re: 1988 Mariner 200 - running great to Horrible in one week.
Quote:
Originally Posted by brownm16
Hi All.
Thanks
Add: This motor does not have oil injection. serial # 6427305. hooked to a dual battery setup.
  #3
Old July 14th, 2006, 09:29 PM
HI,, any mechanics out there that could point me in the right direction..:^
  #4
Old July 14th, 2006, 11:57 PM
andy6374 andy6374 is offline
First off when asessing a motor that is starting to have trouble, start with the basics.
Check compression and make sure there is spark at all six cylinders.
The coughing is possibly due to a lean condition. This can be caused either by dirty carbs or an ailing fuel pump. Try squeezing the primer bulb when the problem occurs and if this cures the problem then it's time for a fuel pump rebuild. If not it might be time for a carb disassembly, soaking, blowing out and drying every orfice with compressed air and then reassembly with new gaskets.
  #5
Old July 15th, 2006, 08:51 AM
Kevin W Kevin W is offline
ethanol based gas may have cleaned out your fuel system and deposited junk in the carb.
the new gas also pulls alot of moisture out of the air and the water forms at the bottom of the tank.
always make sure your vent is closed when not in use.
  #6
Old July 15th, 2006, 08:18 PM
Great point. This is a good place to start. I forgot about the ethanol plague.8)
It will require some fuel system checks anyways.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bad week ended great! deputydawg Dockside Chat 13 December 10th, 2005 09:03 AM
Running great, but running lean???! Beater Mercury & Mariner Outboards 7 September 9th, 2005 04:56 AM
rough running 1988 50HP Mariner mcgurk34 Mercury & Mariner Outboards 0 March 4th, 2004 09:55 AM
WHAT A great week NOSLEEP Dockside Chat 1 December 20th, 2003 08:35 PM
Running great. Now what?? xp150 Yamaha & Suzuki Outboards 2 March 5th, 2003 05:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
