  #1
Old July 9th, 2006, 01:09 PM
imported_William imported_William is offline
Default 1985? Evinrude yachtwin 4hp spark plugs? gear oil? location of water pump/impell
I have a 1985? Evinrude yachtwin 4hp pull start and I have a few questions...
What weight gear oil do I use in the lower unit?
Where is the water pump/impeller? I think I need to replace it but I cannot find it...I have taken apart most of it...but still cannot find it...are there any sites on the web that show pictures? I have a repair manual bu it isn't helping much...I need pictures specific to the motor I am working on.
What are the right spark plugs for the motor?
The Model No. is E4BRHLCOB and the Serial No. is B100991
It says on the tag that it was manufactured in Brugge, Belgium...is this the right year?
Any info would be greatly appreciated...thanks.
William
  #2
Old July 9th, 2006, 01:28 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: 1985? Evinrude yachtwin 4hp spark plugs? gear oil? location of water pump/im
Hi William
High viscosity lower unit lube is what you want. Walmart has it. The lower unit must be removed to access the water pump. The correct plugs are Champion QL86C gapped at .030. Here a pic of the lower unit with the waterpump:
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old July 9th, 2006, 01:40 PM
Rick,
That is fantastic! Thank you very much! Where do I find the picture that you attached that will have all the names of the numbered parts showing? Thans again!
William
  #4
Old July 9th, 2006, 04:21 PM
Scaaty's Avatar
Scaaty Scaaty is offline
http://epc.brp.com/default.aspx?brands=ej&lang=e
Navigate around the above link/ website. Ignore the first page asking for info, just search the catalog. All kinds of diagrams
Your motor is simple (I have a 84)
Pull the 2 bolts out of the lower. They are facing up. Rubber mallet, few taps and its in your hand. Pull the 2 screws off the impeller cover, up and off the driveshaft. Impeller MIGHT come with it. Please remember the direction of the bent vanes, so when you put the new one in, its bent the same way. This is a must (turning the prop will give a hint if you mess up)
Now, as you do this, there is a TINY "T" shaped key for the impeller. Its in the driveshaft. You lose this, it will wreck your day. Get a magnet on it and keep site of it. They grow wings. New impeller, little Vaseline on it, in and now the fun part. Putting it back on requires finesse. Driveshaft. water tube, and shift all need to go in as one. Just take your time, don't force anything, and when it goes in properly, you will feel it.
  #5
Old July 9th, 2006, 04:24 PM
Scaaty's Avatar
Amazing..that diagram don't even show the impeller key!
Whoop, never mind..#17 probably
Quote:
Originally Posted by rickdb1boat
Hi William
  #6
Old June 30th, 2007, 01:25 PM
m51373 m51373 is offline
Default Re: 1985? Evinrude yachtwin 4hp spark plugs? gear oil? location of water pump/impell
Hello everybody,
I have the same engine(Model No. is E4BRHLCOB Evinrude yachtwin 4hp 1985) and no manual, maybe somebody can tell me what kind of oil and gas ratio I have to use for this motor. As I found some info about TC-W3 if it is correct type then what ratio with gas I have to use? Any help will be appreciated.
Mike
The info above with diagrams is grate was very helpful for me too Thanks everybody.
  #7
Old June 30th, 2007, 01:35 PM
Hello everybody,
Mike
  #8
Old June 30th, 2007, 01:51 PM
CATransplant's Avatar
CATransplant CATransplant is offline
50:1 fuel:oil ratio for your eggbeater.
  #9
Old June 30th, 2007, 02:14 PM
Thank you very much.
  #10
Old June 30th, 2007, 06:22 PM
Vic.S's Avatar
Vic.S Vic.S is offline
A word of caution.
I have a 6hp 1984 Yachtwin. I found that it was vitally important to separate the lower unit from the leg at the joint at the top of the extension piece. Then separate the gearcase and extension after cleaning up the drive shaft.
The reason for this is that the drive shaft runs in a bush in the extension and will not slide through it until cleaned up. Attempts to separate at the joint between gearcase and extension results in the shaft being pulled out of the water pump with the result that the impeller key wrecks the top of the pump housing. Minor damage maybe if it is only a plastic key but serious if fitted with a genuine manufacturers impeller with a metal key. (incidentally I got a new key packaged with the impeller each time I replaced it)
Also while the lower unit is off connect a hose to the water tube and make sure you get a good flow of water through the motor. If you dont the first suspect in my experience is the grommet at the top of the water tube. #18 in the diagram posted. Unfortunately you have to separate the power head from the leg to get at that.
The diagram is one of the parts diagrams that you access via the link Scatty has given. You need to enter all the engine details, make ie Johnson or Evinrude, year, hp and finally model number ( or the nearest number if yours is not actually listed)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Spark plugs for 1985 Mercruiser 3.0 scottterry Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 27th, 2006 10:10 PM
1985 4hp Evinrude water pump replacement Sailorsaint Johnson & Evinrude Outboards 3 June 24th, 2006 02:28 AM
1985 75HP Mercury O.B. Fuel Pump Location? Parkstribe Mercury & Mariner Outboards 1 May 24th, 2005 11:28 AM
1985 Evinrude 70 hp water pump Frank Beinzo Johnson & Evinrude Outboards 1 October 21st, 2003 04:52 PM
Folding leg Yachtwin / Water pump l94vwk Johnson & Evinrude Outboards 0 August 24th, 2003 07:06 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
