  #1
Old July 8th, 2006, 06:04 PM
pnut pnut is offline
Default Aluminum Boat Transom Modification.
hi all, here is the boat in question.
i bought a new 25 hp motor that i got a great deal. the only thing was that the motor was the last one in stock and was a long shaft model. this weekend i tried it out on the water. the engine sits a little low in the water but runs fine. the only problem is that water starts coming in from the front of the engine between the transom and engine at full throttle.
now my questions is how difficult would it be to raise the transom about 5/6 inches (which is also the extra Length of a long shaft). From the middle of the transom (where the motor would sit) to the top is about 6 inches.
I did a search but I didnÂ’t find anything. Any info would be appreciated.
thx
  #2
Old July 8th, 2006, 06:23 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Default Re: Aluminum Boat Transom Modification.
Rebuild the entire wood section of the transom and make the transom near straight across. 2 good pieces of marine plywood glued and bolted in should do it. You might want to fabricate and extend the center brace to be closer to the top.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #3
Old July 8th, 2006, 06:43 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
we have done this in the past. cut 2 pieces of 3/4" plywood, 5" x what ever you need then using aluminum angle, available a HD or Lowes, thru bolt the angle thru the existing transom, and the addition, using the angle on both sides of the motor inside and outside, it ain't pretty but it worked
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old July 9th, 2006, 10:21 AM
DJ DJ is offline
I'll second the Captains idea.
Just remove the top, end caps and the bolts holding the wood in. Replace the wood with a piece 5-6" taller.
You may be able to get the top cap to fit back on after a little shaping.
  #5
Old July 9th, 2006, 11:58 AM
bob's way is best, do it right the first time.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Opinion on aluminum boat modification cknadroj Boat Restoration and Building 12 August 6th, 2006 05:36 PM
Replace my transom in aluminum boat? Bob Bismal Boat Topics and Questions (not engine topics) 11 March 22nd, 2006 02:00 PM
Aluminum boat transom replacement San Antonio Cop Boat Restoration and Building 2 December 8th, 2005 05:53 AM
Transom in Aluminum Boat Question Bass Runner Boat Restoration and Building 7 May 19th, 2004 02:22 PM
wood transom on aluminum boat nigelbear Boat Restoration and Building 6 February 13th, 2004 08:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
