  #1
Old July 8th, 2006, 02:12 PM
natecollins1 natecollins1 is offline
Default 1978 70 hp Evinrude stall when put in gear
Hi,
I have a 1977 Evinrude 70 hp. I recently rebuilt the carbs, flushed fuel line + tank, performed sync and Link, replaced spark plugs, replaced water pump and lower unit oil. The motor runs fine at idle, high speed and in forward/reverse on flush attachment. The motor runs fine in idle in the water. The motor stalls when put in gear in the water. The compression in the third cylinder is low (65 psi). The lower unit does not appear to be in any kind of a bind. Do you have any further suggestions for resolving this problem.
Thanks,
Nate
  #2
Old July 8th, 2006, 02:19 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: 1978 70 hp Evinrude stall when put in gear
The compression on #3 is the clincher. You might try doing a decarb and see if it comes up. Until then, I believe you will have problems with running the motor. Need to get that straightened out before you can move forward with other repairs...
http://www.iboats.com/bbboard/bbBoard.cgi?a=viewthread;fid=36;gtid=1035555 ] Link [/url]
http://www.iboats.com/bbboard/bbBoard.cgi?a=viewthread;fid=36;gtid=1035563 ] Decarb[/url]
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old July 8th, 2006, 04:40 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you can do a decarb and see it helps, or you can go ahead and pull the head, could be a simple as a head gasket. the decarb is going to improve the performance , but don't run it for long dragging that cylinder. you could do a lot of damage if it is a cracked ring or worse.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old July 8th, 2006, 05:15 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
My de-carb testimonial
I had a low cylinder over 30 lbs lower. I used the OMC spray tuner while it was running and no real improvement, I pulled the plug and put the low cylinder at TDC and flooded it with the tuner spray. I had the motor tilted up and lowered my bow to achieve an almost verticle attitude for the cylinder. I let it soak 22 hours and my low cylinder came back!!!!!! I will venture to say I am impressed and I know the original owner of my 1967 motor. This was the first time it was done.
Be sure when you are checking the compression that you have all the plugs pulled out and hold the throttle wide open.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #5
Old July 11th, 2006, 03:18 PM
Do you think I can change the prop in order to help get past the initial shock of going between neutral and in gear? Right now I am using a 13-14 x 17 prop. If changing will help, what should I go to?
I am trying the power tune now and will let it soak a day or so.
Thanks,
Nate
  #6
Old July 11th, 2006, 03:32 PM
jtexas's Avatar
jtexas jtexas is offline
"motor stalls when put in gear" - recheck your link & sync - throttle plates may be opening before spark advance - also check idle speed setting - good luck with the compression thing.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
omc cobra 4.3l engine stall when put in gear iaafu Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 March 24th, 2004 04:45 PM
sucking exhaust air causing to stall when full throttle,1978 merc 850 captin 420 Mercury & Mariner Outboards 1 July 30th, 2003 06:41 PM
Stall when put in gear dmizzoni Mercury & Mariner Outboards 1 June 9th, 2003 01:53 PM
1978 Evinrude comes out of gear phinfan Johnson & Evinrude Outboards 2 July 13th, 2002 11:15 AM
1978 Evinrude 35HP comes out of gear phinfan Johnson & Evinrude Outboards 2 July 10th, 2002 03:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
