  #1
Old July 7th, 2006, 04:15 PM
Rogue I Rogue I is offline
Default Prop Issues with 1997 225HP Evinrude--WOT RPMS
I have a 1997 225 Rude that was rebuilt this past winter (new wisco pistons, etc etc). I followed break-in to a tee, and the engine runs great!
I have a 1978 23' Mako with 19 degress of deadrise. Current prop is 15x17aluminum. Hull should weigh apr. 2500lbs (hull only). With about 50 gallons of fuel, myself (200 lbs) and of course the 480lb Evinrude, I can only push 5300rpms for 32mph or so. So, I moved down to a 15.5x15 aluminum, and can get about 5500-5600rpm and 34mph.
My questions: 1) Dont I want to be hitting more like 5700-5800 at WOT (I rarely run it there btw)? Should I move down in pitch? Is the engine mounted too low?
2) Isnt 34mph for WOT a bit slow? It runs at like 26mph at 4200rpm.
THanks for all your help. If the 15.5x15 is the wrong setup, I need to know soon so I can take it off and return it
  #2
Old July 7th, 2006, 04:42 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Default Re: Prop Issues with 1997 225HP Evinrude--WOT RPMS
The numbers with the 15 show about 21% slip...a bit high...
Speed taken with GPS?
Do we know the tach is accurate?
  #3
Old July 7th, 2006, 05:32 PM
Yes, with GPS and with my transducer from the FF. Tach is pretty accurate, I do believe.
I can raise the engine one more hole--should I? Anything else I can do?
Thanks!
  #4
Old July 8th, 2006, 01:31 AM
walleyehed's Avatar
Are you saying you have one set of holes left to be all the way up on the transom?
If so, where is the Anti-ventilation plate in reference to the boat bottom?
  #5
Old July 8th, 2006, 11:50 AM
They seem about even--let me double check.
  #6
Old July 13th, 2006, 09:25 AM
Okay, I looked again, and the anti-ventilation plate is it seems a few (3-6") below the bottom of the transom. This is a rough estimate because the boat is in the water moored.
Should I raise the motor one more bolt? Should I go down in pitch? Should I ventilate?
I'm really confused 8) What slippage numbers are okay/acceptable for my setup?
Thanks!
  #7
Old July 13th, 2006, 11:40 AM
walleyehed's Avatar
It's hard to tell if it's in the water...
It kinda sounds like, if you have to lift engine to last hole, and AV plate is still below bottom of boat, we have the wrong shaft-length motor on that boat.
  #8
Old July 13th, 2006, 01:03 PM
I may have misjudged. I have a 25" gearcase, so it cant be the wrong height...
Where should the anti-vent plate be?
Either way, it sounds like it should come up a hole huh?
  #9
Old July 13th, 2006, 03:10 PM
walleyehed's Avatar
It "should" be even with, if not slightly above the boat bottom.....at the lowest point if it's a stepped hull.
  #10
Old July 17th, 2006, 04:40 PM
It is even with or slightly above the hull bottom right now. I can have the motor trimmed way the hell up though and still have the prop in the water however.
Perhaps moving up a set of holes is worth a shot?
  #11
Old July 17th, 2006, 09:35 PM
walleyehed's Avatar
It's very unusual to have an engine in the highest position, and yet the AV plate is just now "even" with boat bottom.....strange set-up......
Well, if we can't go any higher, we need to find a prop that runs best at that heigth...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 evinrude 225 wot rpms/prop cornholio Johnson & Evinrude Outboards 6 October 21st, 2005 09:37 AM
1997 evinrude 50 prop choice. michaelj1978 Johnson & Evinrude Outboards 23 April 11th, 2005 10:39 AM
rpms 1997 200 efi rmassie487vs Mercury & Mariner Outboards 1 September 1st, 2003 06:44 PM
1997 50HP Johnson loses and regains rpms @ wot andrewi Johnson & Evinrude Outboards 5 January 5th, 2003 11:49 AM
1997 johnson ficht 150hp loss of rpms gorman Johnson & Evinrude Outboards 2 July 16th, 2002 10:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
